Buongiorno a tutti,
a customer reports to me a problem with DXF files.
He loads them correctly, but the cross to select the zero point does not appear.
I uploaded the same file to my PC and everything works fine.
Has anyone had the same problem?
Thank you in advance
Emanuele
Problem with DXF file
- CNC Control System Serial Number: various
- report_0008DC111213-0130231434_2024-02-05_13-19-00.zip
- (5.56 MiB) Downloaded 17 times
Re: Problem with DXF file
this part is super simple, and would take less than 60 seconds to program in intercon.
the circle in the center is not a proper circle.
i opened in a cad system fixed the circle saved it and it opens fine in intercon
Buongiorno,
I know it's a very simple file.
Our customer is recently approaching programming with Centroid, following manual and posted videos.
The problem occurs with any DXF file, this was an example that he sent me to try to load it in my laboratory, where it is loaded and processed correctly.
Thanks for the suggestion.
Emanuele
Emanuele
if customer wants to use a dxf file i suggest using a CAD/CAM system to create the G code.
and use intercon for the conversational style programming, that is it strength.
