one shot programs- where to get them?
- CNC Control System Serial Number: CNC12-m39-104028
I'd like to add the "one shot" features to my Oak lathe. Where can I get those routines to adapt to the Oak? Had features like those on the Anilam lathes that you set the tool where to start and select a feature and rotating the hand-wheels it would run the path while you rotated the other.
Rob Jackson
RJ Technical Services
Re: one shot programs- where to get them?
Look up parameters 188-199 in the operator's manual.
I do understand the macro options with those parameters but, specifically does anyone have a chamfer, radius, facing etc..
Rob Jackson
They are part of Intercon and are called by adding the function to an aux key.
The Intercon program files which are automatically loaded when you use the various one-shot Aux keys are in the c:\icn_lath directory.
They all have names that begin with "__os". E.g. "__oschf_.lth" for the one-shot chamfer program.
You should never need to load and edit those programs through Intercon, the way you would load and edit an ordinary part program. They are loaded automatically when you press the associated Aux key.
Thanks Marc, Exactly what I was looking for!
Rob Jackson
