Greetings All,
Does anyone have the manufacturer's part numbers for the matching connectors to the MPG and Probe connections on the Allin 1 DC?
Connectors on "Allin 1 DC"
Re: Connectors on "Allin 1 DC"
If I can source them locally, I can avoid the shipping and Customs delay; it could be two weeks.
My schematic has the shell and contact part numbers. They are available in the States from Digikey, but I suspect most of the electronics distributors in you area stock them as well.
Hi Tom,
What is the ID of this schematic? I cannot read any of it , nor can I zoom in to make it legible. Another option would be to just include the shell and contact part numbers. Thanks.
You should be able to tap on the image and then zoom in. You can't zoom from the forum page. You can also right click and download the image and then zoom to your heart's content in your favorite image viewer. It's a hi-res png image.
Tom,
Are you sure about those Amp part numbers for the probe and jog panel plugs?
I am pretty sure the ones Centroid uses are Molex Mini-Fit Jr. series.
For example, Molex 39-01-2100, 39-01-2120, and 39-00-0039.
Marc, you are probably right. I measured the receptacles on the board and and came up with those plug PNs that fit. I'll have to update my schematic with your correct parts. Thanks for pointing that out.
