I am adding a function to my mill and would like to use the Aux9 output contactor, calling it up with an M Code in program (Both ON & OFF)?
Aux9 output is currently actuated by Aux3 Key.
This was used for a spindle brake pneumatic solenoid long before I acquired it (Don't need or use).
Not sure how to check and see if M Code function was set up?
Aux Contact output mapping to M Code
Re: Aux Contact output mapping to M Code
I did some research and found the YouTube videos of PLC programing.
I believe I have it figured out.
