Computer will not start reliably
PlasmaCNC
CNC Control System Serial Number: SN:20783
Post by PlasmaCNC »
I have had recently a couple of times were my computer would not start on my Centroid equipped machine. It took several power cycles and in one instance just sitting with power on but no activity the computer eventually started. Looking at the schematics the drawing for the computer does not reference the insides of the computer as far as PC board type or power supply type. I’m hoping its simply a PC power supply that is failing and is hopefully a commodity design that I can simply buy a new one and install. If it’s the PC itself I’m hoping it to is not a novel design and that I can simply
replace it also if it’s a problem. The OS is on a SD card hard drive and is Linux.
Is it possible to get the details of the computer and power supply type for my machine?
The details of the machine, we have had the machine from new and never changed anything. The machine is ~ 15 years old and has been relatively trouble free tell recently. It’s made by Atrump Machinery Inc. It’s a model E216 / Maximill SN: 168. It has a Centroid controller M-series, CNC10 Version 2.32 DC310 SN:20783. The spindle controller is a Delta VFD-V.
- Ed
dpascucci_support
Re: Computer will not start reliably
Post by dpascucci_support »
Opening up the console and posting pictures of power supply and motherboard would help us in identifying the internals. The power supply is most likely an ATX or microATX.
Domenic
dpascucci_support
The first two steps in tech bulletin 272 will help you check if the power supply is bad.
Domenic
centroid467
Post by centroid467 »
Link to TB272 if you are having trouble navigating to it: https://www.centroidcnc.com/dealersuppo ... ds/272.pdf
