Greetings,
Have Knee Mill with older control. Model M-10.
After morning start-up and boot-up I can move
all 3 axles in manual mode, but when I hit cycle
start to run a program I get no movement and
immediate message--- Motor(s) To Hot; Job cancelled.
Any ideals ?
Motor(s) Hot
- CNC Control System Serial Number: model 10 ser. 1418
Re: Motor(s) Hot
I moved this post into this forum.
Re: Motor(s) Hot
Re: Motor(s) Hot
What values appear in the message box, in the upper right corner of the screen, when you press Alt-T?
Post a picture of the screen.
Assuming the motors are in fact cold, you could exit to a DOS prompt (usually Ctrl-Alt-X) and delete the CNC7.TEM file (DEL CNC7.TEM). Then restart (CNC7M4).
