Hi Folks,
I am trying to use intercon to generate 2d code for simple cuts. It adds a Z axis home that trips up the software since there is no Z axis. I have been manually commenting out and adding a M00 to allow me to set the quill and/or knee.
Is there any work around for this so I don't have to comment out z moves? Or do I have a setting incorrect?
I couldn't find any previous pertinent posts.
Jon
allin1DC controller on 2D eztrak intercon use
Re: allin1DC controller on 2D eztrak intercon use
Intercon will only output Z axis moves IF you have a Z axis configured. Post a report from your machine so we can see how it is set up.
- CNC Control System Serial Number: 0222192163
Thanks tblough. Report is attached.
Jon
Jon
I also just attached a pic with the line of code that gives me trouble highlighted. I added the parentheses to comment it out.
Thanks again,
Jo
Thanks again,
Jo
