AXIS6 ENCODER DIFF ERROR ON BENCH TEST
- CNC Control System Serial Number: A901239
New to cnc oak system trying to bench test and keep getting spindle axis6 encoder error.
Re: AXIS6 ENCODER DIFF ERROR ON BENCH TEST
Did you plug an encoder into axis 6 encoder connector?
If you don't have a spindle encoder, you should change Parameter 35 to zero.
I don't have an encoder yet. I will set 35 to 0 for now and try. thanks for the response.
