https://centroidcnc.com/usersupport/sup ... emtest.pdf
Page 5 section 5.1
5.1. Home Switch test. The machine home test starts by checking the values stored
in the plus/minus home switch fields in the Machine Configuration – Motor
screen.
There are two checks made before the test begins. The program first checks the
“Machine home at pwrup” setting in the Control Configuration. If set to “Jog”
the test is skipped and a warning is logged in systest.out. In most cases it should
be set to “Home switch” or “Ref Marks - HS”. The second check looks for any
axis that has at least one home switch input defined except for, rotary configured
axes or axes with an “M”, “N”, or “S” label. Reference Mark homing will have
both plus/minus home switches set to zero. So any axes that fail this check will
generate a warning in the systest.out file.
Acer e-Mill Anilam to AllIn1DC conversion build
- CNC Control System Serial Number: A901038
- CNC Control System Serial Number: 0008dc111213-1223222881
Re: Acer e-Mill Anilam to AllIn1DC conversion build
Figured I owe everyone an update.
The mill is back to making chips.
Thanks for all the help and input and putting up with me.
I will be back soon....
Okay great! Show us some pictures of what you're making or a short video on YouTube!
Here you go.
right on, cool thanks for posting, what are they?
Dovetail markers. For laying out dovetails for woodworking.
Here us an early prototype
cool! thanks for posting the photos.
