File uploads/downloads via Ethernet cable
- CNC Control System Serial Number: 20551
Hi again.
I have been trying to find some info on how to handle file transfers between my M400s console and my PC. I am running CNC 10 v1.51 on Linux 2.271. Serial #20551.
The console shows how many bytes were supposedly sent, but never seems to make it to the PC.
I've tried Kermit,.xterm, and Windows terminal to receive with.
Someone please point me in the right direction.
Thank!
Danny
Thank!
Danny
Re: File uploads/downloads via Ethernet cable
4800 7N2 is an unusual choice of serial parameters. Are you positive that is what you have set at the other end?
Have you tried specifying a different "COM" port on the CNC control?
Do you have access to any RS232 troubleshooting hardware? Barring that, a third PC that is known to be able to communicate can be useful as a tie-breaker, to tell you whether the problem is with the configuration at the CNC, or the PC.
Also: are you using a null modem cable? See http://www.cncsnw.com/NullMdm.htm
So I'm getting the feeling I'm confusing 2 different communication methods. I am not trying to use a serial cable for transfer. The controller has a RJ45 Ethernet plug. I am trying to use an Ethernet cable between the machine and PC. The PC recognizes the console, but gives the error no IP address.
I should have been more specific about what I am trying to do.
Yes, I just noticed that your subject line said "ethernet cable".
The "Download" and "Upload" options on the F2/Load screen are for RS232 communication via a serial port. These are primarily used in a "legacy" environment, that is already set up to use RS232 to move jobs to a variety of CNC controls.
If you want to transfer files over a local area network (LAN) connection, see Centroid tech bulletin 168 "Networking Linux Based Controls".
Once you have a working connection, so that the CNC control computer has access to (and is granted write access to) a folder on the Windows PC, then you can use the F7/Utility -> F5/File Ops -> F2/Export option to copy one or more files to that destination folder.
So after reading TB 168, it became quite obvious that transferring files across a null modem serial cable would be the easiest to do. Picked up a cable today and worked perfect. Next time I find a router at a garage sale for $1, I will try to set up the Ethernet connection.
Thanks for your help again!
Danny
Danny
If you are just connecting two computers via Ethernet, you can use a crossover cable and do not need a hub/switch.
I will give that a try! I had never heard of a crossover Ethernet cable. Thanks for the info!
I'm still at it. Got an Ethernet crossover cable and tried it. The PC would show unknown network and diagnostics said no valid IP address.
Picked up a used router this morning for $4(yeah, I went over budget) and hooked it up. PC recognizes the router and shows it as a network, but the controller isn't visible on the network. Light on the router shows the controller is connected.
The Linux did not have a cnc10.net file so I created one with a path. I have no clue if I did this correct. I will attach pics of the shared folder link Windows told me to use and a pic of it on the controller using the format TB168 shows. Linux at a command prompt uses forward slashes for dividers. Windows uses back slashes. TB 168 shows using forward slashes. CNC10 shows using back slashes. And I have no clue which to use...
I have tried to follow the TB 168 on network connections, but it is written for Win7/8 max. Does anyone have updated instructions for Win10?
Thanks!
Danny
Thanks!
Danny
What does your cnc10.net file say?
From a command prompt on either computer, are you able to ping the IP address of the other computer, without error?
Ping appears to work, but controller isn't viable by the PC.
