Direct controlled Pump (Lube Oil Pump For Bridgeport)
rderkis
CNC Control System Serial Number: A900325
Post by rderkis »
Docs say these are the best lube pumps to use but I cant find any reference to them on google. I must be using wrong search words. Who makes these and how are they listed? Does bijur make them?
Centroid_Tech
Re: Direct controlled Pump (Lube Oil Pump For Bridgeport)
Post by Centroid_Tech »
It is not a particular type of lube pump. Direct controlled just means that the machine's control actually activates the lube pump. Automatic lubrication systems will have a control built into the system that regulates when and for how long to lubricate a system. I am assuming that you are referring to parameter 179 of the Centroid software. The attached tech bulletin should help you.
215.pdf
(78.7 KiB) Downloaded 501 times
lots of lube pumps on ebay.
elrod sells a good one as well.
http://elrodmachine.com/CNC%20Auto%20Lube%20Pump.htm
