If there is nothing plugged into H2 (the smaller power header), then I assume you have a 4-wire plug from the power supply plugged into H3 (the larger power header)?
What is the DC voltage between the yellow wire and either black wire, on the power plug on H3?
Lube Pump Alarm 405 on M400s
Re: Lube Pump Alarm 405 on M400s
Also, what is your control serial number?
It would be on the door of the control cabinet, and also on the back or side of the console.
It is probably somewhere in the neighborhood of 20170.
- CNC Control System Serial Number: many
i have a blurry pic at home with me looks like 20192 i can verify in the morning
thanks
Joe
thanks
Joe
verified SN #20192
sorry i missed this onecncsnw wrote: ↑Wed Feb 08, 2023 8:09 pm If there is nothing plugged into H2 (the smaller power header), then I assume you have a 4-wire plug from the power supply plugged into H3 (the larger power header)?
Yes there is a 4 wire plug plugged into H2
Yellow and either black 12v
Yellow and either red 5v
I assume you meant red to black was 5V. If so, then your power supply is okay.Yellow and either black 12v
Blacks are commons (0VDC)
Red is the +5VDC supply
Yellow is the +12VDC supply.
It is likely that your SERVO3IO unit has an on-board failure in the drive section, and will need to be sent to Centroid for repair or swap-out. I recommend contacting Centroid Tech Support to get an RMA and find out availability of a swap-out unit.
Ok i will give them a call. thank you so much for your help.
Joe
Joe
thanks Keith, sent email to support at 10:30 this morning. waiting to hear back
Joe
Joe
