Software enhancements request
Re: Software enhancements request
I probably posted this earlier in a wrong thread, so forgive the double post.
I'd like a "display" tool diameter in the tool table. I use tool wear compensation so none of my tools show up when graphing.
for physical knobs we are looking into encoder dials with centroid made pc board to pipe signal rotary dial signal via USB to CNC12
occustoms
Post by occustoms »
cnckeith wrote: Mon Apr 17, 2023 9:11 pm for physical knobs we are looking into encoder dials with centroid made pc board to pipe signal rotary dial signal via USB to CNC12
i would like to use regular rotary switches for inputs and use those inputs for rapid rates. Obviously having marc do the plc to implement this.
That wont be an issue right??
It will make it easier for me when i do another machine to make my own pendant into the control panel like i've done on my other 2 machines. I kinda like old school look and feel of switches vs the usb keypad or even the wireless pendant buttons and knobs. I'm not really digging the feel of the actual buttons on those styles. Just my .02
thanks for posting the photo!
this is the way we are headed for the new M400 console design.
tblough wrote: Mon Apr 17, 2023 8:02 am I probably posted this earlier in a wrong thread, so forgive the double post.
good one. adding to the list
classicgameswi
CNC Control System Serial Number: A900294
Post by classicgameswi »
Any progress on adding a rapid override feature?
classicgameswi wrote: Wed Aug 02, 2023 6:50 pm Any progress on adding a rapid override feature?
Yes, we are testing it in-house right now.
thanks, i added it to the list
v5.07 rev15 release notes with coverage of Rapid Override controls attached.
cnc12_v5.08_release_notes_rev15.pdf
(1.05 MiB) Downloaded 19 times
xr4x4ti
Post by xr4x4ti »
This is probably a huge request. If Centroid has this, I am have not seen it.
But, the Prototrak controllers by SWI have a feature called TRAKing. Basically it allows you to step forward and backwards through the program using the MPG to test out a new program. It is very useful.
If this is not clear, here is an example:
Does Centroid have this and I somehow just missed it? If not, it would be a great feature to add.
Tim
PS, I have a Centroid converted Trak DPM mill that I absolutely love. I just purchased its mate, a Trak 1745P CNC lathe. The lathe is currently full functional an I am going to keep the Trak controller for a bit, but the long term goal would be to do a Centroid conversion, but I would loose this feature that the current Trak controller has.
