Hello
I need to know backlash compensation is available during jogging .I remember in some version lash compensation is disabled in jogging and working only in auto mode .
I have a dialing center position error problem in X axis ,it's 0.035mm shift from center
Please clearly
Backlash compensation in Jog mode
Re: Backlash compensation in Jog mode
15.3.119 Parameters 216 | PC Based Lash Compensation on/o
This parameter controls which Lash Compensation Algorithm to use. The default value of 0 is
recommended because it allows lash compensation to occur during any kind of motion. If PC Based lash is
used then only during an MDI or programmed move (but not during jogging) will lash compensation be
applied.
Function Value
Use MPU-Based Lash Compensation 0
Use PC-Based Lash Compensation 1
*NOTE: Lash/Screw Compensation Acceleration Coecients (parameters 208-215) are not used by
PC-Based Lash Compensation.
applied.
Function Value
