I have a mill that has an Allin1dc control. The machine came with the TT-1 probe. So there is an 8 pin connector that's installed. I have a probe that I would like to use that has a 3 wire output that is normally open. One is for 12v dc power, one is ground, and one is for signal output. I've wired the 12v and ground (pin 2=12v,pin 3=gnd), but not sure where the output signal should go. Any advise on the pin number.
John
Probe wiring
- CNC Control System Serial Number: 929110276
Re: Probe wiring
Gracias
