I am in the process of considering my options for converting a Dynapath Delta 20 control with something current. The AllinOneDC has been suggested and it does look like a nice option. My servo motors are Baldor 120VDC max, 31 in/lbs, 10A, 39A max. The schematic for the Delta 20 Suggests it has stepdown transformers to 110vac and 120vac, but I know one of the 1.5KVA transformers has three taps for 79vac. This would rectify to about 112vdc. I assume that would be sufficient to feed the AllinOneDC DC power input for the servos?
Jeff
Replacing a Dynapath Delta 20 with an AllinOne
Re: Replacing a Dynapath Delta 20 with an AllinOne
Hi Jeff,
The ALLIN1DC will be happy with 112VDC for VM.
