mpg to dc3io cpu10
megamachine
mpg to dc3io cpu10
Post by megamachine »
i am trying to hook up a mpg to dc3io
i have an low cost mpg. the computer has an 25 pin header
i need the pin out to hook up the mpg
attached is a report and mpg diagram
thanks
report.txt
(90.83 KiB) Downloaded 6 times
eng199
Re: mpg to dc3io cpu10
Post by eng199 »
The jog panel will determine if it is possible. It is probably the vintage that will have a 12 pin connector. If it only has a 6 pin MPG header, it will not work with third party MPGs.
The MPG must have TTL (not line driver) A/B wheel signals for that era control.
https://www.centroidcnc.com/dealersuppo ... 619.r1.pdf
megamachine
ok is it possible to connect an mpg to this card
eng199
Post by eng199 »
No. Connector is on the PCB behind this:
You do not connect the MPG handwheel to the CPU10, nor to the DC3IO. You connect the MPG handwheel to the jog panel board. As eng199 noted, later CPU10 jog panel boards have a 12-pin header for third-party MPG's, while some earlier ones only have a 6-pin header for a Centroid-manufactured MPG.
Incidentally, the CPU10 board in your picture would not work with a DC3IO. Either you have a grab-bag of mismatched components, or you have a ca. 2001-2004 control with a SERVO3IO (not a DC3IO), that was upgraded with a CPU10 board ca. 2010.
eng199
Post by eng199 »
cncsnw wrote: Tue Oct 04, 2022 12:57 pm Incidentally, the CPU10 board in your picture would not work with a DC3IO.
Good catch and good information, thanks cncsnw.
megamachine
YES you are right it is a servo3io
sorry for the confusion
