Vcp not communicating with oak board
Chas
Post by Chas »
Hi, my system has been working perfectly but I haven’t fired it up in quite a few weeks as I’ve been busy with other stuff. On switching on today when pressing cycle start to home the axis nothing happens. On checking there is no 24v on the output of the estop from the oak board so the servos aren’t powering up. Could an inadvertent windows update have caused this issue as I can’t think of anything else as the estop circuit is closed as it should be.
Re: Vcp not communicating with oak board
I am not sure what that has to do with the VCP.
If you are putting 24VAC into OUT1 COM, and not getting 24VAC out of OUT1 even after you press and release your emergency stop button, then either:
1) The control is still in a Fault condition, or
2) The fuse for OUT1 is blown
