servo jumping
- CNC Control System Serial Number: A900702
servo jumping
I had to replace my Y axis servo. A friend gave me 2 DC servos from a Milltronics. When I put either one on the machine the motor will spin fast for just a brief second when that axis tries to home. It shows a 410 Y axis position error and SV stall error. I switched with the X axis and they do the same over there. The motors seem to check good and run on the bench if I put voltage to them. I don't know of any reason why they wouldn't work.
Re: servo jumping
Did you check the encoder rotation direction?
https://centroidcncforum.com/viewtopic. ... tion#p1657
Re: servo jumping
Thanks for the response. I haven't had time to get out there today hopefully I can get it going tomorrow.
Re: servo jumping
Thanks, got it going polarity needed changed.
