Hi folks,
We have Centroid with Allin1DC on a mill. The MPG is not working in MDI, but it works fine if we get out of MDI. We use keyboard jogging. The manual says ALT W should engage MPG, but it's not the case. Anything we are missing?
Thanks, M
Re: MPG is not working in MDI
you can change the plc program to allow the mpg to be active in MDI mode. typically this is not a good idea..but as long as you know thats the way your machine is configured...
drop an email to tech@ajaxcnc.com and they will let you know how to make the change.
