Hello,
Our company recently purchased a third hand CNC mill with a 4x10 bed and two independent z axis'. Everything works well save for the W axis (4th axis?). I've run Gcode that uses everything else though.
It seems the last owner had temporarily disabled it at it didn't show up on the DRO initially. I changed parameters 130, and 131 to 490, and 60 respectively. However, when I use the jog panel or MPG it doesn't send any power to the drives. As well, the end stops don't show up in the log when I manually trigger them. I know how to tell the machine which pins to use but I dont know how to identify which pins its using. I also dont know how to configure the two spindles in the software. I am not sure if I need to set parameter 42 to treat it as Z axis? It seems like the machine doesnt know to send to the right drive output as I get no voltage on the motor pins at the controller.
If anyone could point me to any references that explain how to use a 4th axis not as a rotary axis. That would be great.
I attached some photos that hopefully provide some context for what I am working with.
Re adding previously disabled 2nd z fourth axis
- CNC Control System Serial Number: 0820102383
Re: Re adding previously disabled 2nd z fourth axis
If the 4th axis limit switches are wired to the 4-pin Phoenix plug H1 on the RTK2 unit, then they will not register as PLC inputs (therefore no "407 ... limit tripped" message on the screen); but they will still inhibit the servo drive in their respective directions.
Set Machine Parameter 94 = 0 to specify that the fourth axis is not a rotary axis.
Optionally, set Parameter 94 = 64 so that the fourth axis (W) gets some of the special treatment that the Z axis gets automatically (e.g. separation of rapid moves to keep tool clear, movement with M25 and M6).
When you "use the jog panel or MPG" and it "doesn't send any power to the drives", what messages appear in the status window?
If you post a Report here, then we can see what your machine configuration and parameter values are, and what error, stall, and fault messages might have appeared.
Oh interesting. Yes, this appears to be the configuration of my system.If the 4th axis limit switches are wired to the 4-pin Phoenix plug H1 on the RTK2 unit, then they will not register as PLC inputs (therefore no "407 ... limit tripped" message on the screen); but they will still inhibit the servo drive in their respective directions.
I have tried both but will set to 64.Optionally, set Parameter 94 = 64 so that the fourth axis (W) gets some of the special treatment that the Z axis gets automatically (e.g. separation of rapid moves to keep tool clear, movement with M25 and M6).
It gives 411:W axis full power without motion. Along with the (current?) bar at the axis going straight to red. However I read no voltage at the W + and - pins on the servo controller.When you "use the jog panel or MPG" and it "doesn't send any power to the drives", what messages appear in the status window?
Attached.If you post a Report here, then we can see what your machine configuration and parameter values are, and what error, stall, and fault messages might have appeared.
- report.txt
- (139.11 KiB) Downloaded 19 times
- report.zip
- (85.77 KiB) Downloaded 17 times
