Hello
When will centroid launch or have any plan to use absolute buffer type encoder as a standard in oak to eliminate limit switch .Most of the new m.c has no limit switch .
They are using buffer type absolute encoder as a standard.
Absolute Encoder In oak as a standard with yaskawa or delta
Re: Absolute Encoder In oak as a standard with yaskawa or delta
No, absolute is supported with OpticDirect and Yaskawa drives. I don't know what you mean by "buffer type".
HICKORY with EtherCAT drives will be the the way to get additional absolute encoder support in the near future.
- CNC Control System Serial Number: CNC12-m39-104028
Rob Jackson
RJ Technical Services
