Work offset changing in the middle of a program
- CNC Control System Serial Number: 0008DC111213-0319211116
Has anyone had the problem of your work offset (G54) randomly changing in the middle of the program.
Re: Work offset changing in the middle of a program
Not without issuing a G52 command. Are you sure it's the same WCS and there is not a call to another WCS in your program?
A G92 would do that too.
Or, if you are talking about a lathe control, then a G50 with X, Z, U or W coordinates.
Post a copy of the CNC program here, along with a Report from your control.
