Screen display
- CNC Control System Serial Number: 6750
Screen display
Hi I have a M400 control (year 2000) on a machining center, for some reason the display is to large and no longer fits the screen , any help much appreciated
Re: Screen display
post a photo so we can understand the issue.
Re: Screen display
See https://www.centroidcnc.com/dealersuppo ... ds/114.pdf
Your LCD panel settings in the motherboard BIOS probably got reset to 800x600 instead of the correct type of 640x480 panel.
Re: Screen display
[media]
[/media]-
Re: Screen display
Your right cncswn .. I’ve checked bios and it’s set at 800x600 but I can’t seem to be able to change it .. any idea why ?
Re: Screen display
I have now managed to change resolution and the display size is now fine , however when I boot up it just sits on this screen saying unable to load language (see attached)
Re: Screen display
Any ideas ? Thanks
Re: Screen display
First impression is that the LANGUAGE.MSG file, which contains all the on-screen text, has either been corrupted or deleted.
If you have a working floppy drive or network connection, and the technical ability to move files around, you can:
1) Unpack the attached ZIP file to get the LANGUAGE.MSG file
2) Copy it into your C:\CNC7 directory
- LanguageMsg823.zip
- (84.86 KiB) Downloaded 41 times
Re: Screen display
I have a floppy drive and I think I could unpack the zip file and copy the MSG file to a disc ok … but I think copying it to the C:\CNC7 directory on my control is a bit beyond me. Is there any chance you could tell me how to do that in a kind of computers for dummy’s way ?
