Working on completing the set up. 6.6 Homing the machine.
The CNCM.HOM file was not in the directory so I created it per installation instructions.
M92/Z
M26/Z
M91/X
M26/X
M92/Y
M26/Y
Set to home on power up using limit switches.
Press start and X - SHOWS UP hit run and homes to x- limit and backs off limit switch.
It stops and I have to manual change directions and axis.
XY and Z all can be manually homed.
Should this be automatic and start with Z+ when I start homing?
Thanks Phil
6.6 homing the machine ALLIN1DC ON MILL
Re: 6.6 homing the machine ALLIN1DC ON MILL
It is likely that Z did move, but you did not notice.
If you are not certain, jog each axis so it is an inch or more away from its respective home/limit switch, then start the homing sequence.
After "it stops", what error message(s) appear in the status window, in the upper right part of the screen?
What does "manual change directions and axis" mean?
What does "X - SHOWS UP" mean?Press start and X - SHOWS UP hit run and homes to x- limit and backs off limit switch.
