How to wire vfd spindle forward and reverse?
Deere103
CNC Control System Serial Number: A901133
Re: How to wire vfd spindle forward and reverse?
Post by Deere103 »
I have a day at home and trying to make some progress with the retrofit.
Thanks you for the software that supports ATC, I will try that this afternoon.
Current issue, I ordered 2 different RS232-USB cables to communicate with the servo packs, however I cannot get sigmawin to find the drives.
I called simgawin support twice but they haven't been able to offer much help. I'm also using the same cable the first tech guy recommended with the prolific chipset.
Drivers are installed correctly and computer recognizes cable, I changed the COM port to "COM1" per yaskawas tech support direction, but still I have no luck in communicating with the drives.
Do you have any ideas or is this something you've seen before?
thanks
