No pendant or touch screen how do I toggle MPG
- CNC Control System Serial Number: 0008dc111213-1119212671
I broke the touch screen but I want to test the encoder I am using for the handwheel. I don't see a hotkey to toggle the MPG, do I need to edit the PLC program to have a way of toggling the MPG?
Re: No pendant or touch screen how do I toggle MPG
The MPG can be toggled on/off either from the physical operator control panel if installed, or the VCP. You do not need to edit the PLC.
Use a mouse to click on the VCP button.
