Hi,
I'm adding an external Cycle Start, Feed Hold and a Tool eject button to my Oak. I have one spare input IN16, so I need two more. Can I commandeer any of the existing inputs, for example high, mid or low gear? From what I read the limit switch inputs are effectively reserved, but I'm not sure if the same applies to any of the others. I understand that the PLC will need changing to remove existing functionality etc.
Julian
Spare Inputs
Re: Spare Inputs
On the Oak, you can use any input you want. PLC will have to be edited if you are using it for something other than the default.
Re: Spare Inputs
Thanks Tom
