Hi I was wondering if any one can help my machine seems to have developed a mind of it`s own when i run a program it does`nt follow the G code it does random things.It was fine the night before i`ve tried writing them in Fusion 360 and the built in Intercon with CnC12.When it`s supposed to face it does as in the pic and the video i`ve uploaded.
Bridgeport with Allin1DC.
https://photos.app.goo.gl/JnaXdyemDEXqB3SQ8
Help Needed.
Re: Help Needed.
That is kind of intriguing. Maybe a combination of very low PID gains and disabled stall detection; or perhaps completely off-the-wall Smoothing parameters; or inappropriate use of cutter diameter compensation.
If you were to post a Report and a copy of the CNC program, then perhaps we could make some informed guesses.
- CNC Control System Serial Number: 0324202376
Re: Help Needed. Fixed.
Hi Cheers for the help with the ideas to check some how the smoothing was turned on don`t know how as i never use it .The magic of the forums all back to normal now.
