5-Axis Wizards,
I finally got my bench test completed (with 5-axis sim. contouring activated), but, I can't get this simple 5-Axis move to work (see pict). It works fine with any combination of 4 axii (normal mill software), but add the 5th axis to the line, and it gives a 509: Option not available, and a 544: Too many axes, errors - like the 5-Axis Simultaneous Contouring option is NOT activated. I have the CNC10 2.66+ 5-Axis Sim. Contouring unlock that Centroid sent me installed and it shows in the Report's machine parameters as active. I'm running CNC11-D Mill v3.16. I never installed CNC10.
Is the unlock incompatible? Do I have to install CNC10 and then upgrade it to CNC11?
All-In-One 5-Axis Sim. Contouring
- CNC Control System Serial Number: 0110181888
- report_0110181888_2022-04-05_00-09-38.zip
- (170.14 KiB) Downloaded 37 times
Re: All-In-One 5-Axis Sim. Contouring
Report .zip added. Note: All dates in this report, except today's date (4/5/2022) are ca. two years off, i.e. 2020 = 2022.
Reported Generated: Tue Apr 5 00:09:38 2022
MPU11 serial number: 110181888
Version:
CNC11-D Mill v3.16
You will need to contact Centroid to obtain CNC11-C or CNC12-C.
Another Boston Digital fan?
1983 Bostomatic 300. Upgrading from 1st, Aerotech U500 upgrade.
I found the CNC12-C Mill v4.14 stuffed away on a backup drive. It took less than 5 minutes to upgrade to it. I'm set now. Thanks again!
