Automation Direct PLC
I read some where a while back that an Automation Direct PLC could be hooked up to read and write to the memory registers of a centroid control system. Is this so? If so do you have any info on wiring and com addresses.
Re: Automation Direct PLC
Communication with Automation Direct PLC's are no longer supported.
Is this for an older system or new?
New systems. The c based PLC side of the centroid controller is antiquated and a little hard to use. We are gearing up to start refurbishing machines as a main buisness and I need to find a good controller that I can program more effiecently.
