Axis coupling i think its called.
schric11
CNC Control System Serial Number: Oak = A900768, AllinoneDc =A000430
Post by schric11 »
Hello,
I was wondering if on a bed mill with a centroid control if the Z axis was the head movement and there was a scale on the quill. When you moved the quill in or out if the distance moved Could add or subtract from the Z position on the control?
Thanks.
Re: Axis coupling i think its called.
hello. yes. that feature is called: Z axis summing. the guys in tech support can send you the setup details.
schric11
Post by schric11 »
thanks
