When I go to probe bore. It travels, hits the surface, backs up (X3 Times). Then throws error "Probe unable to detect surface." If it did not detect the surface, what stopped it
Thanks in Advance.
~P
What type of Touch Probe do you have? Do you really have a DSP Touch Probe because it looks like you have it configured as such.
viscoelastic wrote: ↑Tue Jan 04, 2022 10:39 pm
Swissi,
Thanks!! its always the simple things that kick you. Appreciate the help.
~Visco
You are welcome.
If you want to make WCS probing easier, verify what overall, real world probing accuracy you can expect from your probe and machine and increase overall probing accuracy with Precision Probing, have a look at the ProbeApp which has been adapted to works with the Servo version of CNC12 also.
-swissi
