KP-3 probe error 504 invalid parameter, line 98
- CNC Control System Serial Number: A901011
getting an error, when trying probe bore cycle. hit cycle start and get this error code. 2 axis cnc mill cnc12,m39 control system id 0008DC111213-0503211124 thank you.
- report_0008DC111213-0503211124_2021-12-23_11-58-59.zip
- (3.89 MiB) Downloaded 43 times
Re: KP-3 probe error 504 invalid parameter, line 98
You can't use automatic probing cycles with a 2-axis machine. You need Z controlled by CNC12 to automatic probe on most of the probe cycles. I don't know if you can use the x and then the y middle auto cycles without a z-axis. Give it a try and see if that is a work-around.
