system test fail 511 line 1020 vfd
- CNC Control System Serial Number: A901011
first time posting here I have a 2 axis mill with a oak control, mpu12 system id 0008DC111213-0503211124 , when I run a system test I get alarm 511 line 1020, i did Verify that INP13 shows red in high, green in low range. If I manually control spindle in high or low range and Tach it it matches readout on the control. same if i turn spindle on MDI mode with s specific spindle speed and direction code. I have a automation direct GS23-25PO drive on a 4 hp spindle motor. I have attached a zip report and the VFD parameter setup list file from drive if that helps. Thank you.
- gs231223.xlsx
- (98.51 KiB) Downloaded 48 times
- report_0008DC111213-0503211124_2021-12-23_11-58-59.zip
- (3.89 MiB) Downloaded 57 times
Re: system test fail 511 line 1020 vfd
You can't run probing cycles on a two axis machine. You need a full 3-axis machine.
Change your manual-axis labels (axes #3 and #4) to 'N' while you run the system test.
