repauli1 wrote: ↑Sat Dec 18, 2021 5:47 pm
Well the issue was not code related, BUT reading the plc code and how it interacts with macros gave me the ability to track down two issues I had. The Carousel had stopped functioning after lengthy rebuild and testing, which required some addition adjustments. Then I found that the Carousel would stop in between bins, I finally figured out I had to inverse my counter prox, now everything works.
Nicely done! Thanks for bringing this to a close.
Question, is your carousel bi-directional? It seems as it took "the long way around the block" to get to tool 1 from tool 3?
martyscncgarage wrote: ↑Sat Dec 18, 2021 5:59 pm
[quote=repauli1 post_id=57577 time=1639864045 user_id=8x24
Yes it is, but need to troubleshoot the Rev rotation on motor, I had it working, but will not rotate reverse right now.
