I am a little confused, in the manual it references G30 (return 2 wcs) as Carousel change position. Is this the position above changer to allow tool changer clearence to move under spindle? Or is it the Clamped/Unclamp position of Z?
Bob
Setting for Z heights for tool change
Re: Setting for Z heights for tool change
It is the carousel level, at which tools are unclamped and clamped.
Most M6 tool-change macros for umbrella-type systems use Z home (machine zero, maximum height) for clearance height while the carousel rotates.
Thanks, that clarifies my thing!
