Posts: 1984 Joined: Thu Sep 23, 2021 3:49 pm
Post
by suntravel » Wed Jun 22, 2022 8:44 am
tblough wrote: ↑ Wed Jun 22, 2022 8:21 am
Which seems correct - arc moves between +0.288 and -0.288. So (0.288*2)+9.525 = 10.101
jep usually the error is in front of the CNC
You will also have to consider, that if Vf F200 on the outside of the bore is needed, in this case write Vfc F11.39 for the G2 moves.
johnballard
Posts: 32 Joined: Wed Feb 19, 2020 11:49 am
CNC Control System Serial Number: 0818141095
Post
by johnballard » Wed Jun 22, 2022 8:18 pm
Hi I have attached my circular pocket definition and the incredibly descriptive error.
I'm pretty sure the error is between the keyboard and the floor.
Lagunmatic 250
Posts: 3102 Joined: Tue Mar 22, 2016 10:03 am
CNC Control System Serial Number: 100505 100327 102696 103432 7804732B977B-0624192192
Post
by tblough » Wed Jun 22, 2022 9:20 pm
Well, for starters, you can't do a 0.5mm finish pass with only 0.576 left on the diameter to take out. Your finish pass can only be 0.288 max and that leaves you no room for ramping on your rough cuts.
johnballard
Post
by johnballard » Wed Jun 22, 2022 9:33 pm
OK Tom. Thanks for looking at my pictures. That was it. I feel so ignorant.
btw until the M6 SHC screws didn't fit, I have let Fusion360 do all my gcode. This was my first attempt with Intercon.
Lagunmatic 250
Post
by suntravel » Wed Jun 22, 2022 11:31 pm
johnballard wrote: ↑ Wed Jun 22, 2022 9:33 pm
thats because the circular pocket should be 11mm for the head and 6.6mm bore for the shaft.
IMHO Intercon is faster for simple parts than fusion 360.
