Fusion 360. Post Swissi 005
Up til now no real issue with 360 or Swissi post.
The latest Fusion 360 update changed the post window a bit. Gray and boring.
That is neither here or there.
I am getting an invalid value on line 13 showing E54.
Looks like that should be G54
yes, no, maybe?
I will run it by the 360 board just to cover the bases.
SOLVED: invalid value, F360, Swissi post
- CNC Control System Serial Number: 101981
Dave Koehler
https://www.koehlerinjection.com
Re: invalid value, F360, Swissi post
OK, I have tried several different posts with the same results.
I then opened up some previous successful projects and that E54 does not show. G54 has taken it's place
SOOO, it's something weird with this file.
Found it. It's a 360 gramming error.
Dave Koehler
Re: SOLVED: invalid value, F360, Swissi post
I'm having the same problem but only on one file. Not sure what a gramming error is but I'd like to fix it 9-)
My Tree J325 & Projectshttps://photos.app.goo.gl/LLHf8M84eQYwP3ph6
MAKING PARTS https://www.youtube.com/shorts/MSQ4TyTzFkk
Hardinge CHNC4 Retrofithttps://photos.app.goo.gl/244YnF9ykyUf7mfq7
You can select work coordinate system #1 with either of two codes:
or
An "E54" code would be a request for work coordinate system #54, which does not exist.
See page 221 in the operator's manual:
https://www.centroidcnc.com/centroid_di ... -v4.20.pdf
E1
G54
