How to wire a Delta brand VFD-B to the allin1dc?
jamesriendeau
Post by jamesriendeau »
Hi
Pick up a basket case millport lathe that had an older centroid controler on it. I am up grading to the ALLIN1DC.
The lathe came with a Delta brand VFD-b. And I would like to reuse it.
I am having trouble with the Delta vfd-b manual not calling things the same as the centroid schematic. Has anyone used an older Delta vfd-b in there project? This is my first install and I am kind of shaky if things are not all spelled out for me. I got a friend helping that is a master electrician but it is his first install also. I think we need help.
What do you need to help me? Pictures? Pictures of the vfd terminals? Schematics?
Jim
Re: How to wire a Delta brand VFD-B to the allin1dc?
This schematic should give you an idea. It is pretty straightforward, almost identical to the Automation Direct GS3.
Contrary to this schematic, you should use the normally-closed contact of the fault relay (RB instead of RA).
See also page 2-14 (p28 of the PDF) in the manual.
If you want a spindle load meter, connect AFM and ACM to the analog input on the Allin1DC, and change Pr.03-05 to 1.
If you want a zero-speed indication, wire MO1 to INP12; wire MCM to 0VDC; and change Pr.03-01 to 24.
DeltaVFD-BManual.pdf
(4.02 MiB) Downloaded 76 times
S11047.pdf
(154.29 KiB) Downloaded 80 times
jamesriendeau
I printed out the schematic and took a look at the Delta manual.
Not sure about the spindle load meter. I have not seen the screen of the monitor turned on yet. Would be nice to have.
I will post how I make out.
Jim
