Centroid uniconsole2
Ghosty
Post by Ghosty »
I've been struggling with this console . It's currently setup to use a remote harddrive for the job files, but that is set to a old laptop that is currently not working. How do I route this to another pc on the networks drive
Re: Centroid uniconsole2
That depends on the CNC7 or CNC10 software version it is running.
Supposing that it is running CNC10 v2.32 or later, and you want to load jobs from the network, but run from a local copy, then you would set Machine Parameter 4 to a value of 5; and you would edit the cnc10.net file to specify the drive letter, path, and login credentials for the network location.
