Cnc12 install
- CNC Control System Serial Number: A901017
Cnc12 install
I thought I followed the installation manual for the bench test and after installing the software I get this. I tried calling centroid and haven't gotten a call back. Anybody run into this before? Couldn't find nothing on it in the manual. Thanks
Re: Cnc12 install
There are errors showing in your message box.
Please generate a system report using the utility screen (F7) > Generate Report and post it here. You can save the report to a thumb drive and upload it here. You can to attach the report file when you post here.
Re: Cnc12 install
The second pic is where you save the report. Save it to the directory shown on top (cncm) or a thumb drive. An empty thumb drive is better because them you will know it is the current report without trying to figure out which file we need. Attach that file to your post.
Re: Cnc12 install
Ok i really appreciate this. Hopefully this is right....
- report_0008DC111213-0503212622_2021-08-11_11-04-43.zip
- (465.45 KiB) Downloaded 73 times
Re: Cnc12 install
Also note, the message about "setup not complete. machine is not ready to run" will not go away until the system test is run and completes successfully.
https://centroidcnc.com/usersupport/sup ... emtest.pdf
Re: Cnc12 install
Thats good to know, Thanks! Now the only code that is there, that the manual says shouldn't be, is 304 MDI... ?tblough wrote: ↑Wed Aug 11, 2021 12:14 pm Also note, the message about "setup not complete. machine is not ready to run" will not go away until the system test is run and completes successfully.
Re: Cnc12 install
"304 MDI..." is just a status message that means -- at least when the message appeared -- that the F3/MDI prompt was opened.
It is not an error or a fault.
Re: Cnc12 install
Are my All in One DC videos on YouTube helping? Are you following the All in One DC Installation manual EXACTLY?
How about some details about your build?
Re: Cnc12 install
Hi Marty, thanks for the reply, yes I got it figured out I think. I made it through the bench test successfully. I am retrofitting my Republic Lagun 310 three axis vertical mill. It had a dynapath delta 20 controller with baldor dc servo motors. I appreciate the help,, I'm sure I'll have more questions
