4th axis installation
Posted: Thu Jun 17, 2021 9:49 am
by ernieflash
i want to install a fourth axis on my M400S Seriel number 20344 knee mill
my operating system is cnc10
I want to make it a full 4th what parts do i need
and what type of rotary motor do i use Servo ?ac?dc?
thanks
Re: 4th axis installation
Posted: Thu Jun 17, 2021 2:21 pm
by cncsnw
Your control probably has a DC3IO drive/PLC unit powering the first three axes.
http://www.cncsnw.com/Drives.htm#DC3IO
You would need to add a DC1 drive; a DC servo motor; and appropriate cables.
If the DC servo motor you choose requires a lower voltage than the ca. 120VDC that your control supplies to the DC3IO for the existing motors, then you will need to add a suitable DC power supply for the new motor as well.
If the DC servo motor you choose can run on 120VDC, then you can just extend the existing 120VDC supply to the DC1.
Posted: Thu Jun 17, 2021 3:28 pm
Here is the Manual for DC-1:
https://www.centroidcnc.com/downloads/c ... C1_MAN.pdf
Show pictures of your 4th axis.
What size motor (Frame and Power) do you need?
Posted: Fri Jun 18, 2021 8:16 am
by ernieflash
Marty I dont have anything yet
that's what i was asking what do i need to do this .
thanks
Posted: Fri Jun 18, 2021 8:41 am
by tblough
As previously mentioned, you need a DC-1, one of these:
https://www.centroidcnc.com/rotary_tables.htm, and an internal bulkhead cable to connect the two.
Posted: Fri Jun 18, 2021 8:45 am
I'd find my fourth axis first. Then find a DC brush servo, of which I have several.
