Hello
Is there is any way to command axis from .src file?
I need it for control my servo turret or Mill ATC carousal
I don't want to move axis in cncm.m6 or cnct.tch
Aamir
Re: Axis Movement Through .src file
Posted: Tue Apr 27, 2021 3:42 am
by ashesman
You could make a custom macro file say M20 and trigger it from the PLC source. You can assign a m code to one of the aux key functions (refer to 15.3.115 Parameters 188–199 — Aux Key Functions in the CNC12 manual).
Or you could do it through jog or MPG functions while watching the position. Although I don't know if they can be used while in auto mode.
Maybe there are system variables to control the axis but I couldn't see them.
It seems that trying to move an axis in PLC code is not ideal. You would require many iterations and have to monitor it each loop. The PLC code will not stop executing while an axis moves so it is in the correct position for the next step. A macro file however, will let you step through the movements. M codes can be called from this macro file to trigger PLC actions if required.
I have to move the machine head during a tool change while actuating tool rack pneumatics. It will be done entirely using a macro that calls M codes to do the actual output control and input monitoring.
Posted: Tue Apr 27, 2021 9:28 am
by aamir
Ashesman
I am familiar with the Macro
Infact i generate this one
I need now to move axis through PLC or may be use a word W10 and that word may call in macro.
May be there is any new method or update that will directly trigger any axis with in .src file
Aamir
Posted: Tue Apr 27, 2021 12:00 pm
by cncsnw
As far as I know, there are no new features to allow the PLC program to move servo axes. The options are the same as they have been for the past ten years or so.
If there is never a need to run that motor as a CNC-addressable servo axis, then you could potentially wire it to PLC-controlled outputs, and control it using your own PID loop in the PLC program. I have done this for spindle orientation on perhaps a dozen systems.
In that scenario, I think there is one new feature of interest: I think I read in some recent release notes that there are now PLC system variables or output ranges to control the Oak axis-interface analog values, when (and only when) the axis header is not used for a CNC-controlled axis.
Posted: Wed Apr 28, 2021 4:10 am
by ashesman
I just got to watch that video. That conversion looks pretty awesome. Well done. Looks like a fierce machine!
I am sure if you describe in detail exactly what you are trying to achieve someone will be able to come up with an idea...
Posted: Wed Apr 28, 2021 11:48 pm
by aamir
Its a Trumpf CNC punching machine used in fabrication and sheet metals.
Its ATC is a rack Mount with so many protection of Die punch and stripper.
Aamir
