Trouble with keyboard
repauli1
Post by repauli1 »
When I power on any of my 4 servos (DMM DYN4 1.8KW) the 101keyboard stops functioning. The on-screen keys continue to work. I am referring to the Centroid touchscreen workstation.
Any ideas, I am commissioning so the only thing grounded is the 120vac power supply. The dyn4 drives are grounded, but not to electrical panel yet.
Re: Trouble with keyboard
Is the 101 keyboard wireless or USB? If wireless, I suspect noise from the drives.
repauli1
Post by repauli1 »
No it's USB, when I cycle off drive breaker, sometimes the keyboard comes alive, other times I need to unplug, and reinsert into USB. I am going to try running a temporary ground wire across the floor to ground point on main breaker panel.
repauli1
Post by repauli1 »
Grounding drives took care of issue. Thanks Tom
