AllInOne Overheating? Oscillating
johnballard
CNC Control System Serial Number: 0818141095
Post by johnballard »
I have a Lagunmatic 250 10HP vertical knee-mill with AllInOne controller. It's been a great machine in my garage and I have machined more than 500 parts without issues. However, today there were two curious events.
I had been running a series of programs (five tool changes) to build 100 parts. Each part takes about 50 minutes of machine time. There is one operation that forms a contour on two posts that takes 30 minutes of continuous machining. I have ramped the feed rate to 750mm/min so the x and y axis are constantly moving. This operation finished and I changed the tool to a drill, started the program, ALT-S and WTF. It moved off the part by >50mm and the machine stopped - fault. Nothing crashed. I checked the positioning (x, y, z) and everything seemed OK, just that my program never would take the drill where it ended up.
I started the drill program again, deep-drilled the first hole, and while fast moving to the second hole the whole machine started shaking (before the drill had engaged my part - thank goodness). I pushed feed-stop immediately. Shaking stopped. It was like I had a disconnected or slipping encoder. I'm assuming it was the x-axis since the holes are aligned along the x-axis (no y movement).
I stopped my program. X, Y, Z axis displays were shifting maybe 0.001mm. Jog functions were fine. I checked x and y motors - not hot, very dry (coolant was on and recirculating fine) and sounded normal.
I shut down everything, cut main power, and opened the control box. It was 60F today (pretty cool for my region) so the temperature in the box was reasonable. The only elevated heat was on the AllInOne board. The heat did not seem excessive. All the VFD's were cool.
I have no idea what to look at now. Any suggestions?
I'm going to put a fan on the bottom of my control box so there's fresh air blowing through the AllInOne. What else can I do?
100.nc
Includes contour - 45minutes machine time.
(370.1 KiB) Downloaded 2 times
report_0818141095_2021-04-02_22-30-54.txt
(141.34 KiB) Downloaded 6 times
Panduit covers off - sorry
Lagunmatic 250
polaraligned
Re: AllInOne Overheating? Oscillating
Post by polaraligned »
I would check my PID motor tuning. In particular, if Kd is too low the motor can bust out into oscillations. As for overheating, that probably is not the case but I don't see a fan in that cabinet. You should have filtered fresh air coming in low and an exhaust fan high.
Agreed, I think its a servo motor tuning issue. You might post the make and model motors here and what the DC buss voltage is. Maybe Marc can suggest something with more information. (Post a picture of the motor label)
Try reducing Ki on all axes to 0.002.
I would also double the Y axis acceleration time (from 0.107s to 0.215s), and cut its Ka in half to match.
johnballard
Attached are the motor labels. The DC circuit is a full bridge fed by 120vac = ~170VDC. I did add a negative temperature coefficient thermistor 2R025 in series.
I'm surprised by the recommendations you guys made, but I will follow them; I know you are the experts. I will explain. I've logged hundreds of hours of machine time with no issues at all. I did perform the tuning process when setting up the almost-new controller and drives. It's just that these two events occurred after having run the mill >4 hours really hard. I was considering that the situation was an anomaly that occurred on a well-tuned machine, rather than a condition that is a machine not set correctly.
Lagunmatic 250
polaraligned
That X axis motor is only rated for 100v - the voltage constant and max speed tell you that. Sometimes they printed the max voltage on the label, sometimes they didn't. I would replace that with proper motor for your supply voltage or use an step down transformer. The Y axis motor is a monster at nearly twice the stall torque as the X axis motor and probably overkill. I use this era Baldor servos on my Series II machine, and used them on a Series I machine that I have since sold.
