Hi all, Its been some time since I purchased my second retrofit kit from Ajax. Just started the bench test all is fine with the hardware
FPGA-OK = Solid green
DSP Debug = Flashing
DSP - OK = Solid Green
+5V = Solid Green
My problem is software. CD = Mach3 Plugin & Documentation v1.14
The CD makes reference to Mach3 software must be installed first, my manual also makes reference to Mach3 software from Newfangled Solutions, LLC.
My question is do I need to purchase this software and If I do what version as the Newfangled site is not clear ( to me )
The PC is running windows XP
Thanks in advance for your help.
Dave
**Resolved** MPU11/DC310B Bench Test
Re: MPU11/DC310B Bench Test
I have just found out that I need to purchase the Mach3 from Newfangled
Dave
Dave
Hi all,
I have been thinking overnight do I need the Mach3 software ?? $175.00 from Newfangled
Can someone just confirm that I do need to buy the Mach3 software in order to run my machine as I do have the Centroid CNC software.
Thanks in advance
Dave
Thanks in advance
Dave
If you purchased the Centroid Software there is no need to use Mach3. A unlock sheet with your permanent unlock should have been sent along with your order for the Centroid Software. If you did not receive this please contact sales@ajaxcnc.com with your control serial or invoice number and we will send you another copy.
Thanks Ajaxliviu
Yes I do have my Software Unlocks sheet.
Thanks for a quick response.
Dave
Dave
