Rackmount Tool Change Example
Centroid_Liviu
Post by Centroid_Liviu »
Attached are samples of an M6 that performs rackmount tool changes as well as the associated PLC program. PLC involvement is minimal in typical rackmount systems with the PLC only being used to turn on and off the tool unclamp output although in some cases the PLC also needs to turn on an output to open a cover, pull up the dustfoot etc...
rackmountm6.txt
(4.75 KiB) Downloaded 271 times
allin1dc-rack.txt
(95.37 KiB) Downloaded 267 times
