Hi,
Any advise on this type of encoder - Renco ENCODER RS25D-1000-3/8-5-LD0M1
I have look online but unable to find any info on this type of encoder.
Please check attached image of encoder.
Regards
Manni
Haas VF-1 1994 Retrofit to Centroid Allin1DC - Spindle Encoder
- MPU11 & GPIO4D -w/ 3rd Party Drives: Yes
7804732B977B-0624192192 - Location: Boston, MA
Re: Haas VF-1 1994 Retrofit to Centroid Allin1DC - Spindle Encoder
Just a quick guess that it's a 1000 line 5V line driver encoder with a 3/8" shaft. You'd have to check the Renco website to be sure.
If the MS connector is a 10-pin 18-1 pattern, then there is a reasonable chance that it is a differential encoder, and uses the same pin-out as a US Digital HD25 or Koyo TRDA-25 model.
See https://cdn.usdigital.com/assets/datash ... 7600845398
and https://cdn.automationdirect.com/static ... series.pdf
Thank you tblough & cncsnw,
The TRDA-25 model was the perfect match.
