Still struggling to get hand wheels operational.
Hi, i have modified the plc program as per Tom Blough's post of Sat Sept 5th but still no life in the hand wheels. I have rechecked the wiring and everything is as it should be. hand wheels are connected to axis 3 & 4 inputs. I'm guessing i'm missing a step somewhere in getting them to act for Axis 1 (Z) and axis 2 (X). Any suggestions greatly appreciated.
Report attached.
Chas
Report attached.
Chas
- report_0528190794_2021-02-10_14-57-49.zip
- (189.12 KiB) Downloaded 8 times
Re: Still struggling to get hand wheels operational.
If you made necessary changes in your PLC program source, did you then compile the new PLC program into mpu.plc?
Hi, er no I didn’t. Is it simply a matter of removing the standard oak src file and pasting in the revised one.
Many thanks
Many thanks
- MPU11 & GPIO4D -w/ 3rd Party Drives: Yes
7804732B977B-0624192192 - Location: Boston, MA
All the Centroid manuals are located here: https://www.centroidcnc.com/centroid_di ... nuals.html
This one will show the PLC compile and installation procedure: https://www.centroidcnc.com/centroid_di ... manual.pdf
Soory guys but still struggling with this. Have altered the Centroid Lathe-Standard-Oak-r4.src file and the MPU.plc file to match but still no joy. I believe the software brings up an alert when a change is made to the program but i don't see that so i assume i haven't made the changes correctly. i have noted that the mpg button on the vcp cannot be changed but that may just be that it only functions when a centroid handheld pendant is attached, i don't know. The handwheels are operational as if i switch axis 3 and 4 on i get readouts from both when i turn the handles. Very frustrating as everything else works great now. Report and copy of modified src file attached.
- report_0528190794_2021-02-20_16-39-20.zip
- (182.98 KiB) Downloaded 5 times
- Centroid-Lathe-Standard-handwheels_v3.src
- (154.03 KiB) Downloaded 6 times
You don't edit mpu.plc in a text editor.
You edit your source file in a text editor, then compile it.
Suppose you have decided to name your new, revised PLC program source "Centroid-Lathe-Standard-handwheels_v3.src". Then, with a command prompt window open, and in the c:\cnct directory (so the prompt in front of your cursor reads "C:\cnct>") you would enter the command:
mpucomp Centroid-Lathe-Standard-handwheels_v3.src mpu.plc
After you type the "mpucomp" command, then look to see whether the resulting messages include something like:
... plus some statistics about program complexity and size.
If you don't see "Compilation successful", or the output file is not "mpu.plc", then your changes are not going to take effect.
Input file : Centroid-Lathe-Standard-handwheels_v3.src
Output file: mpu.plc
Apologies, but i must still be doing something wrong. Went through the procedure as explained but i get the response as in the attached photo. Any suggestions.
cd c:\cnct
Two different commands. First changes to the cnct directory. Second compiles the plc program.
Thanks guys, got there in the end with your help. Handwheels along with everything else now fully operational .
Many thanks.
Chas
Many thanks.
Chas
